Hey all. So, I'm in the process of mocking up my 505 stroker...440, .030 over, etc...(Factory iron block, TrickFlow aluminum heads)
I have Fel-Pro 1009 gaskets, and I drop one on the block and to my dismay, the fire ring is over-hanging the factory chamfer by a noticeable amount. These gaskets are supposed to be 4.410" in diameter. Everything I am reading says this is a no-no situation because it will trap combustion pressure under the ring and lift the gasket...
So, what are my options? Cometic MLS 4.500" ? Rubber-coated Copper 4.500"? LS swap? (J/K)
68 Dart - 440 Swap in Progress...please stand by
