Head Gasket Woes? Fel-Pro 1009
#3222633
03/25/24 08:56 AM
03/25/24 08:56 AM
Posts: 32 Pennsylvania
19_Dart_68
Pennsylvania
Hey all. So, I'm in the process of mocking up my 505 stroker...440, .030 over, etc...(Factory iron block, TrickFlow aluminum heads)
I have Fel-Pro 1009 gaskets, and I drop one on the block and to my dismay, the fire ring is over-hanging the factory chamfer by a noticeable amount. These gaskets are supposed to be 4.410" in diameter. Everything I am reading says this is a no-no situation because it will trap combustion pressure under the ring and lift the gasket...
So, what are my options? Cometic MLS 4.500" ? Rubber-coated Copper 4.500"? LS swap? (J/K)
68 Dart - 440 Swap in Progress...please stand by
Re: Head Gasket Woes? Fel-Pro 1009
[Re: 19_Dart_68]
#3222638
03/25/24 09:16 AM
03/25/24 09:16 AM
Posts: 2,663 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Some blocks have a gigantic chamfer in the top of the bore and all I know to do is go to a gasket with a bigger hole. My friend recently had the same problem. I feel your pain. The Fel-Pro 1105 is real big, gasket hole 4.59. I wonder if they have anything in between? If not you will have to change brand.
2011 Drag Pak Challenger
[Re: 19_Dart_68]
#3222642
03/25/24 09:28 AM
03/25/24 09:28 AM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you think the block is bad check it out on the head. Edelbrock head fit is terrible
[Re: NITROUSN]
#3222653
03/25/24 10:38 AM
03/25/24 10:38 AM
19_Dart_68
Pennsylvania
Is this one is ok for 10.5:1 compression ratio?
[Re: Stanton]
#3222671
03/25/24 12:17 PM
03/25/24 12:17 PM
Posts: 1,996 Apollo, PA.
B1MAXX
Apollo, PA.
x3 I ran them at 14 to 1. 10.5 should be no sweat I think fel-pro says good to 12 to 1
[Re: AndyF]
#3222686
03/25/24 01:06 PM
03/25/24 01:06 PM
Posts: 4,693 Wichita
GY3
Wichita
With Trick Flow heads you should go straight to Cometic gaskets. Don't bother with any of the cheap stuff, order the correct parts and do it once. x4! I tried Fel-Pro's with my 505 build initially and had issues. No issues with Cometics (I've used 2 different thicknesses) over the last 9 years. Lots of abuse and a rowdy jug!
[Re: GY3]
#3222849
03/26/24 10:16 AM
03/26/24 10:16 AM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
My suggestion is anyone considering the Fel-Pro 8519 look into the 17059 Marine gasket instead: https://board.moparts.org/ubbthread...38/fel-pro-17059-marine-head-gasket.html
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
