Some blocks have a gigantic chamfer in the top of the bore frown and all I know to do is go to a gasket with a bigger hole. My friend recently had the same problem. I feel your pain. The Fel-Pro 1105 is real big, gasket hole 4.59. I wonder if they have anything in between? If not you will have to change brand.
2011 Drag Pak Challenger
