Talk to Cavert to see what they say. It might work if you take out half the leafs. My guess is that the SS springs by themselves are too stiff so you would need to remove leafs to make the spring softer. But I don't really know. I've always used a split monoleaf spring with the Caltrac bars. The split mono leaf is lightweight, adjustable and it works.
