For what it’s worth, Aviad is advertising the entire setup on their website for 3700.00. You will probably want a bigger tank than what they offer, they can be had from Stefs or Petersen. I’m not sure if their prices are up to date, but their pan depth would probably fit above your K member with no trouble. Take a look at Aviads website, you may find it interesting. Dry sump was worth it for me, about 25 additional horsepower on the dyno. Bes ported my 440-1 and manifold, I do have aluminum rods and higher compression than you may want, but I made 850hp easily with my bill miller aluminum block. Mine is 572 also. I understand the radical part, my car is strip only.
