per the manual the UCA, LCA and spindle should be in place WITHOUT the UCA bumperand hanging. Then do the following. DO NOT tighten any of the bolts on the UCA bushings or LCA pivot until the suspension is fully loaded with the engine etc. and the initial height is set
