Bet if you had 5.13's that purple shaft would be the clear winner...
Then again, I'm NOT known for having anything resembling common sense regarding comfort/drivability.
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
