The only reason why I say the starters are different is when I use my other starter plate with the 318 converter, the little starter bendix will hit the ring and not allow you to mount the starter when you put in the big starter it will allow you to mount it.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
