Like said above most of your after market performance manifolds are blocked any way so it would be of no advantage to go through the work to chip it out and risk getting carbon spread through the engine. See if your intake has open ports that match these before attempting to clean it. If not leave it alone.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
