Originally Posted by Cab_Burge
Originally Posted by randavis
He did say several times that it was a numbers matching block and it cost somewhere in the neighborhood of $20 grand for the engine build. After the extreme heat on the block during welding, it required the cam bore and main bore to be re-bored and the block head surfaces had to be squared. It was overbored .040. It had bushings in the lifter bores.
That's a lot of cash to save an old 383 block. Also mentioned was that the transmission was not original. Worman kept saying the original block would increase the value $50 grand, which I find hard to believe, especially since the transmission wasn't original.
When people over state the actual market value they are either stupid or greedy work
Me thinks they are greedy tsk down rant
The two are not mutually exclusive. In fact, they often go hand in hand Cab.
