Depending on the year of the car, someone has surely figured out how to create a "numbers" block. And the result would be better than a patched up piece.
I've heard of that being done on other make engines.
"Numbers" trans should also not be difficult.
Disclaimer: I'm not advocating fraud. Just commenting on the possibilities.
If the results don't match the theory, change the theory.
