a mess but fixable. My 727 failed earlier this year , sheared and ground up oil pump lugs while cruising up the freeway @ 60mph . 15 year old probably 55/75000 miles , north of 1200 passes , Not as much HP as you but more weight . Only upgraded to a Griner rmvb and solid front band after breaking 2 flex bands . On the back burner as i have another built tbrake unit . Will get billet oil pump gears and super sprag this time . Pricey buying good parts with the Aussie peso .
They are plenty tough for most of us bracket racers .
Tex
