Originally Posted by Stanton
Sounds like you're missing the spring that goes behind the ball in the switch. The spring is needed to keep the ball in contact with the lever. Without the spring the ball just bounces as it pleases in addition to nothing to make the contact in the switch work..
You could buy the new switch but I'd be pulling the side cover to find that spring - unless its laying on you bench somewhere !!
If the spring were out of the switch I would suspect the ball would also have fallen out Correct ? shruggy
