Car - 1970 Dodge Challenger 340 4-speed. Chased an electrical Gremlin down to the reverse switch in the back of the trans. When I jump the harness switch, backup and dash reverse lights come on. However, when I plug in the harness, nothing. If I remove the switch and push it in with my thumb, everything works. I can see through the switch hole, that the reverse lever inside the trans it right up against hole. I confirmed that the linkage is adjusted properly, and when I manually push the reverse linkage as far back as possible, I can't get the switch to close. It's as if the little ball needs to be in another 1/8 inch or so. The switch looks like a factory part. Did anyone ever have this problem? Is there an improved or alternate switch that reaches a little deeper into the trans?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
