Originally Posted by NITROUSN
Originally Posted by Wolfe440
Good suggestion trying a second gauge to insure accuracy, and I do have a second gauge and worth giving it a try. Its bran new in the box, just have to find it....
Main reason is I have seen many people here as well as other sites chase a problem only to find out it was a gauge accuracy issue. About the simplest and cheapest repair/test at this point. If the pressure is the same I would remove the pump and measure everything or just buy a new pump as they are cheap and easy to swap out. Heavier oil is just a band aid in my opinion.
I got a new gauge, its showing 30lbs at idle and its hitting almost 70lbs by 2000rpm.
Silly me, trusting an old test gauge, I won't make that mistake again.
Got a lot of good info from this thread, thank you all for the help!
Wolf
