The 1/2 shift under acceleration may be normal, depends on the torque converter, the looser the softer, the tighter the harder. The 2/3 flare is most likely the band releasing to soon. I'm not a fan of the TG kits in the OD transmissions. Use a flat blade screw driver and pry the band apply lever down and see how much gap you have between the lever and the servo. You only need about 1/4" minimum. So start there and adjust looser if you get a little binding.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
