I think 10 clutches in the direct portion of the overdrive unit is normal or 22(?) of the one sided discs. Extra clutches for the actual overdrive would be awesome. These would be the ones you see when you pull the overdrive unit off the trans.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
