Thanks for the info. I will add another. Cascade transmission machines 48RE internals- 6 pinion steel planet gears, increased capacity clutch packs, etc to fit the regular 46rh. Parts they have allow for up to 10 clutches in the OD unit. I think you can buy entire already assembled overdrive units from them, and the rest is basically like building a 727.
