Went back and read a few reply's, the guys are right hats too many threads showing. I someone hasn't already suggested, a easy and quick fix, is a set of lash caps. Standard valve diameter is 3/8, after market like Eddy, Indy etc use 11/32, and Hemis are even smaller, get some thick ones..Like .080-.100 thick that have the small oil hole in them...Shouldn't run you no more than $40 shipped from the parts store.
[color:"red"]65 Hemi Belvedere coming soon [/color]
[color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
