How much oil pressure do you have , pull the rocker shaft and crank it on the starter, oil should fly out the hole feeding the shaft
Thats what I would do right now to see
if you have the supply... while you have the shaft off
OK. Will do.
Soo, what if I dont have the supply? Where could the restriction be?
You should be able to run a stiff wire(welding rod
tig type) and bump into the cam going down the oil
port in the head
Also put the rocker shaft hold down bolt in the hole
when you test for oil... it could be blocking it off
which would mean the oil hole coming up isnt big
enough... also the hole in the rocker shaft might
be too small to allow the oil into the shaft...
just things to look at
