I'd start with verifying the gauge isn't lying about the oil pressure being low. Use a real mechanical gauge.
That said as before Mike just run it if it blows then deal with it i ran a 351 with a rist pin knock and low oil pressure for 40,000 miles and if you need I have a 460 here
