Originally Posted by NITROUSN
Because it is a weak link and an under designed system for today's higher output alternators. So the ammeter and associated wiring and connectors are the weak links. End result is melted wiring and fire potential.
Not so much the ammeter, per se. But poor connections on it & the bulkhead connectors.
