ah HA ! your response finally sank into my feeble dumb mind !
i THANK YOU a LOT !
i believe the saying goes : "can't see the trees because of the forest". quite a lot of times, i fixate on a particular subject or object, then can't think of, or see, the whole picture.
i have hospital appointments later today, and "food gathering" for tomorrow, so saturday will be the earliest i will be able to apply your suggestions.
Thank You again for prodding my old mind into [somewhat] working again like it should !
as they used to say : "film at eleven !"
i'm not sure if there will be a film, and maybe not even at "eleven", but this problem will be found and the results will be told.
