My tractor has a box to trigger a solenoid to cut off the fuel and turn it off when you turn the key off. It died, and a tractor junkyard wanted ~$250. So now I have a string that goes to the injector pump to pull a lever to cut the fuel off
If you ever find yourself in a fair fight, your tactics suck.
