I'm under the impression that most type of alcohol will suck moisture out of the air if in a breathable container, yes or no?
The test tube now, after adding the E98, seems to have a very thin(.030 to maybe .075 thick) layer of some funny looking liquid at the very top, looks greasy almost
EDITED:
I remembered using Lucas E 85 stabilizer in several of the full jugs earlier in the spring of 2019, I wonder if that is the funny looking stuff on top of some of the fuel samples now
I think I will add some more of that to all of the jugs and then retest all of them once more
