90% of a e85 test is over in about 30 seconds and that should get you less than 5% of what it actually is.. This coming from a friend that's very well educated in ethanol fuels in drag racing..
that is what the tech at Quick fuel indicated after consulting with another tech in the office.
I'm testing now after adding some additional E98 to each jug
Mixed results so far, maybe I need help on the math on exactly how much E98 to add to raise it up to E90%
E85 one gallon should have 19.2 ounces of gas and other non ethanol alcohol additives, correct?
I'll add to this post later this evening when I'm done testing the mixes I used
I may have to experiment several times to get all of the jugs to E90
Test, test and test some more to get the results needed to be sure of your results
