Most of the cost of fixing is the time and effort to remove and install the transmission.
You can try to live with it. If its too bad, suggest you get a stock replacement clutch kit (includes TO bearing, pressure plate, disc, alignment tool). The 273 should not need any special kind of performance clutch. Pull it apart and have a local machine shop re-surface the flywheel and put it back together and enjoy.
