‘66 Baracuda. 273 4spd. Just making it run and see if we can go two years driving it before sinking money into it. However, the clutch is shuddering at take off. The clutch has been in a while and has sat a long while. What is the minimum to consider in a fix. TOB, clutch, face off pressure plate, all of the above or something less. The 273 is going to be replaced with a 408 in two years so whatever we do will be chucked then anyway.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
