Clutch Shudder
#2643749
04/10/19 05:57 PM
04/10/19 05:57 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
‘66 Baracuda. 273 4spd. Just making it run and see if we can go two years driving it before sinking money into it. However, the clutch is shuddering at take off. The clutch has been in a while and has sat a long while. What is the minimum to consider in a fix. TOB, clutch, face off pressure plate, all of the above or something less. The 273 is going to be replaced with a 408 in two years so whatever we do will be chucked then anyway.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Clutch Shudder
[Re: dfsmopars]
#2643751
04/10/19 06:04 PM
04/10/19 06:04 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Minimum?
Disc
could be oil on it, clean PP and flywheel.
If time is no issue pull it and see what needs doing.
If you just want to get it done, clutch kit and flywheel resurface.
Re: Clutch Shudder
[Re: ahy]
#2643877
04/10/19 10:02 PM
04/10/19 10:02 PM
Posts: 10,757 North Dakota
6PakBee
North Dakota
Try a couple hard launches. I had a car sit once so long that the disc transferred some friction material to the PP/flywheel. A couple good launches burnt this off and life went on. I wouldn't get carried away with this, if a couple good launches doesn't work, it probably isn't going to.
Re: Clutch Shudder
[Re: 6PakBee]
#2644357
04/12/19 11:11 AM
04/12/19 11:11 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Try a couple hard launches. I had a car sit once so long that the disc transferred some friction material to the PP/flywheel. A couple good launches burnt this off and life went on. I wouldn't get carried away with this, if a couple good launches doesn't work, it probably isn't going to. My thoughts exactly. Also, make sure the motor mounts and trans mount are not broken. Especially the drivers side. You can hold the brake, start to let out the clutch in 1st and see if the driver's side of the motor lifts up. Try it in reverse to see if the passenger side is broken. You don't have to get carried away to see the motor lift, but be careful.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
