Hey Tony, doesn't QA1 sell tubular A arms? on another note a friend of mine actually from your neck of the woods bought a MF tubular front end for his big block Dart years ago and had many problems with the installation. Its actually in another friends Dart now but again it took some mods to make it work.
QA1 does make tubular arms, upper and lower for that matter, but they are the bushing style upper arms. I believe MF, Hotchkis, and SPC are the only companies out there making units that can be adjusted on the car. One could make a set with swedged tubes and ball joint plates from the Speedway Motors catalog, but this would require changing the arm mounting style to a through stud arrangement like a GM.
