James Monroe set my Terminators up with #38 nozzels with a #86 pill in the return.
It wanted to run a little hot more like it did on gas so I went to #39 nozzels and stayed with the #86 pill cured the problem. I had a needle bearing in the roller on a lifter go out at the last race and thought it was leaning out on the top end. When I talked to James I did not know that and he told me to go to a # 80 pill on the return. I hope in the next 2-3 weeks to try it again with the #80 but will also have my #86 with me just in case.
I am also thinking about trying about 20% Nitro in it with the Terminators. Should work also with the Flying Toilets. Has anyone else thought about this?
Last season was my first time trying alcohol with a New Engine also,but I am sold on the Terminators running alcohol the throttle respone is un-real.
