My six pack did that. could be leaning out cause the fuel is moving away from the jets... followed by the fuel causing the floats to drop and add too much fuel into the bowl. This causes the momentary fat mixture until things settle down a bit.
Move your idle speed on up and quit using the brakes!
Also, get an idle solenoid. It is a high idling six packs best friend.
Dallas
