Wow I'll have to print that... I'll be firing this up soon. I HATE those clear sight plugs though. The strip out after about 3 cycles. I was going to say floats but if you've checked them maybe it's a develery problem. Only problems I've had w/ a carb under stops and hard turns was sloved w/ a float level adjustment. Have you treis rasing them a little more than mid-way?
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
