Originally Posted By Morty426
Originally Posted By 69CoronetRT
Paint code 96 is Butterscotch on a Super Bee. I don't think you will find 96 on other Dodges.
If the Dart pictured is car 3443**, it codes 99 NOT 96. Therefore it may be Butterscotch in color but it does not code 96. It codes for special order paint. If the color was released for Darts, one would expect to fine examples pop up now and then.
So what you are saying is that Plymouth used the 96 code and Dodge would have used the 99 code. Is that correct?
Because I encountered a 69 Charger 383 4 speed that was this color back in 1981
96 is Butterscotch, 99 is special order and could be Butterscotch or any other special order color. Butterscotch is Dodge, Bahama Yellow is Plymouth.
