I first started on the engine. I got it running, but since it's no longer running due to a spun rod bearing, I won't go into too much more detail.
After it was running, I started working on the dash, replacing the non-functioning stock unit with a panel from Redline Gauge Works and stuffed with Auto Meter Designer Black II gauges and Detroit Speed and Engineering LEDs.
I wired and installed it all myself.
