Originally Posted By 62maxwgn
From what I see,one is BB,the other SB.
The one on the right in photo 1 is for small block, and maybe slant 6.
My notes have VC-190 as small block, with 11 distributor degrees and starts to add advance around 9" manifold vacuum.
The small block Mopar Performance vacuum advances that I own have 8.5 distributor degrees. My guess is the big block versions were close to that range.
Mancini sells a couple versions for B/RB with electronics or single pooint including VC187.
Any progress on tuning?
