Lose transfer slot? If the mix screws don't do anything, it's likely dropping fuel in from somewhere else (ruptured PV diaphram) or dripping boosters is likely.
Oh,they do.Very strange things but they do
The pcv diaphragm is ok and i haven,t seen the boosters dripping at idle.
I have done several tests today ,engine at 170 celsius and every time a diffent thing occurs here,very confusing.
Let me repeat the tests again,to see if i,m
able to get a better conclusion.I will record another video to show you how this is going on.
Meanwhile a bit offtopic,but i need to order some parts,a vacuum canister for example.The broke unit i got is the part 3656766.I have seen it on the web listed as a part for small block dist.There is another part number for BB i think.
Do you know if this part is correct for this distributor (MP electronic ign)or maybe a previous owner made it to fit ?
