Dang! the original water valve started leaking sometime during the Clinton administration and the replacement xref was the brass thing I just pulled off of there. Add that valve to the list other take off parts I chunked as useless back in the day that are now worth $$$ or are good for cannibalism.
Just to make sure I'm understanding correctly, I need to swap that whole cam/lever assembly that the roll pin in the valve slides in in favor of the one from the correct valve, not just the pin/lever that the actually cable attaches to??
Eyes now open for one of those pivot lever/cam things, if not a whole parts valve. Looking at the interweb pictures available, they must all be stock photos or I just can't see the differences in the lever.
