You might as well have asked, “What cam are you running? The one I am considering is crap because it’s not in your ride.”
You would have received the same results. Comp Cams are only as “good” as they are popular, and that depends on how the wind blows. 🤣
I have no recommendations. Just a comment. I’m running the Comp Cams XE274H. Yes it’s a little noisy. Idles with a nice lump and zero hesitation at idle. Car takes off like it’s on banana peels. 3.91 SG 727 TF. There are probably 20 other similar grinds that basically get you the same place because as you can see, there are lots of guys out there who are enthusiastic about their particular grind.
The one common factor we can all agree on here is that 440 Mopar mills kick butt. With a well-balanced combo of street upgrades, you’re going to have a permagrin behind the wheel.
