Taking a close look that the trans pad. I see that the assembly date is 2461 which is 4-23-68. The vehicle's SPD is 4-18-68
Does this maybe make you question if is the original transmission?
That probably just proves Barry's point that the SPD is just a suggestion.
Yes. If that is the original transmission....
Question about the 1968 BB stripe.
Is it suppose to to be one that goes straight across the trunk lid or does it come to a point in the middle of the lid? Kind of making a slight V if you understand what I talking about.
