if ign1 is the only wire feeding the MSD turn on lead then your only going to have the MSD fire when ever ign1 is hot. it's either when cranking or when in the run position. the MSD wire needs 12v during the crank and run positions. I would just wire both ign1 and ign2 to the MSD turn on lead and move on...
