[quote=Sammy][quote=krautrock] it will be easiest to find the wires that went to your ballast resistor. blue and brown. they come out of the bulkhead connector on the engine side.
those wires tied together and connected to the keyed 12v wire on the msd should work.
Thanks I will report back to you. This is a great help.
