Originally Posted By Sammy
Originally Posted By krautrock
one wire is hot in "on", one wire is hot in "start". they have to both go to your msd box.
I think this is the problem, which wire from the MSD box gets these wires?
I think something got cut.
Would these wires come off of a relay? I see a bunch of relays on a panel but when I wired up my fuel pump, water pump, and fan I didn't use these relays.I think I have 3 relays back up under the dash
it will be easiest to find the wires that went to your ballast resistor.
blue and brown. they come out of the bulkhead connector on the engine side.
those wires tied together and connected to the keyed 12v wire on the msd should work.
