I'm in the middle of doing this same swap in my 73 W200 which also has a divorced transfer case. To deal with the extra length issue I ended up using a 2WD chevy NV4500 with a dodge input shaft swapped in. The chevy tailshaft is way shorter than the dodge one. I need to shorten my driveshaft a bit, but dramatically less than what you are talking about.
It might be less effort for you than moving the T-case and making all new driveshafts and mounts.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah
71 valiant scamp 318/A833OD/AC/PS
00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process
73 W200 Power wagon, PTO winch, 4 spd
