I ended up running two PCV and two screw in breather caps, one of each on each side up on my old 518 pump gas street 400 stroker motor up I had a old set of Cal Custom cast aluminum valve covers on it with a single PVC and breather cap on the other side, it would push oil out of the breather cap when racing it on the weekends shifting at or above 7000 RPM whiney I added three more breathers caps which helped but did not cure the oil pushing out the caps, adding two PVC with two caps did end up curing it thumbs shruggy
I do make and use a crankshaft scrapers also, they help up I run six quarts in a stock 1970/1971 Mopar Street Hemi, 440 six pack oil pan also, I do not overfill it tsk
