Originally Posted By mopar dave
Ok Cab. This is the pan i bought from you. Thought you said to use 1/2 qt over pan capacity to avoid sucking pan dry thru 1/4? Thought it was a 8qt, nope its a 7qt. So you say to use 6qts? May be main problem with oil pushing out with high rpm.
If you are sucking the pan dry on a 1/4 mile pass you have issues.
There is no POSSIBLE way to suck a pan dry like that. If the pick up is .250 from the floor of the pan (depending on the pick up) like it should be you can't suck a 5 quart pan dry in one pass.
I guess you could have some issue with oil return and the heads are holding oil it's POSSIBLE. If that's the case, the fix isn't more oil in the pan. It's to figure out how to get the oil out of the heads.
I thought the old wives tale of sucking pans dry was gone. Evidently not.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
