I'm in the process of installing a Super Sniper on my '65 Coronet. It is a simple system but it still takes a little bit of work to make all of the changes to the fuel system as well as the wiring. You might want to read over the instructions a few times before you buy the kit so you're prepared with all of the parts you need.
