Hello I wanted to add I have had several lakewoods thru the years on alot of them have had to tweek the fork pivot to help alignment with the bearing ears and link from the zbar. have had to cut and weld it to a new position to get it just right on a couple - there far from perfect. Good luck - be patient you'll get it!
