Ok, so I usually adjust my clutches by pulling the inspection cover and use a feeler gauge to set the disc gap.
I just installed a new clutch & pressure plate and swapped the stock bell housing for a Lakewood scatter shield with the block plate which covers everything so no access to the disc to check. How are you Lakewood owners making your adjustments>
Entire Thread
Subject
Posted By
Posted
Adjusting a McCleod Clutch with a Lakewood Scatter shield?
