I cut out a "V" shape for the side wall to the seat mounting. I'll add another piece in this area later. The remaining large flap was bent in two places to replicate the factory bends. Here's what I ended up with. The rear section still has to be trimmed. I gave up using the snips; I used a die grinder with a cutoff wheel.
